Having trouble taking the Throttle cable off my olds 307
Place to post your questions that don't fit into one of the specific forums below.
Nov 28, 2024 | 12:59 PM
NampaCutlass
Oct 2024
Nampa Idaho
I’ve been working on getting this engine out so i can swap it out with a 455 but im stuck on taking off the throttle cable
Chris
NampaCutlass
Find More Posts by NampaCutlass
Nov 28, 2024 | 01:08 PM
Tyroma
Nov 2024
Langton, Ontario
Lift that little tab on the retainer clip and slide it forward. Then the disk should slide off the pin.
Tyroma
Find More Posts by Tyroma
oldcutlass
Oct 2009
Poteau, Ok
Lift the tab and slide the retaining clip forward until the post slips out.
oldcutlass
Find More Posts by oldcutlass
Nov 28, 2024 | 01:16 PM
NampaCutlass
Oct 2024
Nampa Idaho
Thank you
Yall have a good thanksgiving
NampaCutlass
RHD conversion throttle cable routing
kuseetha
11:04 PM
700r4 cable sweep question (on a 455)
sethj78
11:42 AM
Throttle cable problems
MHENDERSON
04:12 PM
Proper Rigging
Wilson05
05:16 PM
307 in a 84 cutlass
87CUTTY
05:50 AM
will chevelle door handles work on a 72 cutlass
04:13 AM
