starter pinion
Old Dec 28, 2022 | 09:04 AM
OldsHollyday's Avatar
Question starter pinion
Hello everybody,
I have an oldsmobile 88 dynamic super Holliday 1963 394 V8, and I'm looking for car parts for this car especially a starter pinion. Would you know where I could it ?
Thank you very much
Véro
Old Dec 28, 2022 | 09:36 AM
Have you tried an auto parts store, rockauto, or any other auto parts suppliers?
Old Dec 28, 2022 | 10:11 AM
Thank you Eric, I'm living in France and I don't know auto parts in USA for this car.
Would you know websites please?
Thank you
Véo
Old Dec 28, 2022 | 10:42 AM
It's called a starter drive assembly. The original GM part number is 1932188. If you search for 1932188 starter drive you will find that this part was used on all 1957-1963 Olds full size cars, in addition to Cadillacs from that period and other makes and models. RockAuto does not list it under 1963 Olds, but if you search by part number for 1932188 on their website, you'll find that Standard Motor Products P/N SDN2 is the replacement and sells for about $28.
Old Dec 28, 2022 | 02:23 PM
Rockauto.com has a wells unit part number WVE2K1015.
click on link below
1963 OLDSMOBILE DYNAMIC 6.5L 394cid V8 Starter Drive | RockAuto
Old Dec 28, 2022 | 03:12 PM
click on link below
Thank you so much for your precious answers Eric. Have a good day
Vero
Old Jan 2, 2023 | 06:29 AM
Received today!!!!
Thank you so much Eric and Joe for your precious halp. I've received the starter today!!!
Happy New Year!!!
Old Jan 2, 2023 | 07:10 AM
Be aware that the biggest issue in replacing the starter drive is getting the retaining ring off the end of the armature shaft. Pull off the stop washer (item 15), then you have to push the retainer collar (13) back off of the snap ring (14). This is retained by the spring force in the snap ring, so it takes a little effort. Once done, remove the snap ring and chase it across the garage. When reassembling, be sure to put the retainer collar back over the armature shaft BEFORE replacing the snap ring (ask me how I know...). I usually use two pliers to snap the collar back over the snap ring. Also don't forget the stop washer.
Old Jan 2, 2023 | 11:00 AM
Thank you so much for your advices, I'll tell you if I succeed to replace it .
Have a good day
Véro
jerbear2
Mar 24, 2022 05:01 AM
stellar
Sep 22, 2018 06:43 AM
88hurstolds
Jan 11, 2013 07:43 AM
gmendozalv
Oct 26, 2012 10:46 AM
cutlassKing
Mar 30, 2007 01:06 AM
