Shift lever spring
Old Oct 30, 2022 | 04:23 AM
Cruzinbill's Avatar
Shift lever spring
I have a Rallye 350 column shift automatic, standard column. The shift lever spring is broken. Is there a replacement spring available?
Old Oct 30, 2022 | 06:15 AM
If you are talking about the shift lever return spring (item #40 in the diagram below), here's a source for new ones. Same spring for model years 1969 and up.
Old Oct 30, 2022 | 06:16 AM
If you are talking about the shift lever return spring (item # 40 in this diagram), here's a source for new ones.
Old Oct 30, 2022 | 11:17 AM
Cruzinbill's Avatar
Thanks so much.
Toms cutlass
Dec 8, 2025 07:41 PM
Jim Kniola
Apr 4, 2022 07:01 PM
Mj119
Oct 3, 2021 10:18 AM
glparker389
Mar 19, 2014 04:46 PM
davidmorrison
Apr 2, 2013 02:29 PM
