Is The AC Muffler Really Needed??
Old May 12, 2020 | 03:05 PM
cdrod's Avatar
Rodney
The AC compressor had been removed from My '72 442 convertible years ago and it sat in a West Texas cow pasture for many years. Unfortunately, mud daubers made homes in the open ac hoses including the AC muffler. I've cleaned and flushed the muffler as best as I could but I'm concerned that I didn't get all the mud out of the chambers inside. My new AC system will include the newer Pro6Ten 10-piston compressor. Here's my question, what was the purpose for the AC muffler? Is it really necessary? I'm thinking the Pro6Ten compressor, with 10 pistons, will have a smoother output than the original 6-piston A6 making the muffler unnecessary. I will need all new hoses anyway, and not concerned about originality. Can I just omit the muffler when I build the new hoses?
Rodney
Old May 12, 2020 | 08:25 PM
Charlie Jones's Avatar
Phantom Phixer
Why not just buy a new hose with a new muffler ?
https://www.ebay.com/itm/68-E72-CUTL...8AAOSwbqpT18aR
Old May 12, 2020 | 09:41 PM
cfair's Avatar
My ‘66 Starfire has run with no muffler for 5 or 10 years, I miss it only for factory looking aesthetics.
Old May 13, 2020 | 05:38 AM
Ozzie's Avatar
Supposedly the muffler was to reduce the compressor's pumping noise. I'd retain it if possible, but the unit will likely work satisfactorily without it.
Old May 15, 2020 | 07:50 AM
cdrod's Avatar
Rodney
The repo muffler assembly that Charlie linked to is $175 - ouch. If I buy the MasterCool crimping tool, can I replace the hose on my existing muffler? Is the #8 fitting off the muffler welded/braised on or can I cut off the old ferrule and crimp on a new hose with a replacement ferrule? Will a replacement ferrule slip over the existing hose barb on the muffler? The Crimping tool is $143 on Amazon, the fittings, hose and ferrules are about $25.
Old May 15, 2020 | 08:08 AM
Phantom Phixer
So you're going to spend $168 ( $143 + $25) to make a hose , when you can buy one for $175 ?
Old May 15, 2020 | 08:45 AM
cdrod's Avatar
Rodney
I need all the hoses for my AC system: total cost of the ready-made hoses is about $390 w/shipping. If I can fix my existing muffler and build the other hoses for the cost of the hose and fittings, I come out ahead financially. With fittings, hoses, and the crimp tool; I'm all in for around $260 and I can keep the correct compressor -mounted muffler. Plus, it's a good excuse to buy a new tool!
Rodney
TomT
Aug 30, 2017 09:45 AM
elcaminodave
Jul 30, 2014 03:53 AM
shaykai
Feb 12, 2010 08:40 PM
72oldscutlass442
Jan 30, 2010 03:33 PM
a1fla
Jun 30, 2007 05:09 AM
