Oil change
Old Mar 5, 2020 | 02:24 PM
Pitbul442's Avatar
Oil change
Has anyone ever heard of adding an extra quart of oil to an olds 455 due to the way the oil return tubes are? I hear that the oil doesn't return as it should and alot of it stays at the top of the motor. Any info is greatly appreciated.
Old Mar 5, 2020 | 02:38 PM
RandyS's Avatar
No, with a stock pan, 5 qts. will do just fine (assuming you are changing the filter also). As always, check the level after you fill it.
Old Mar 5, 2020 | 02:40 PM
Pitbul442's Avatar
Thank you.
Old Mar 6, 2020 | 05:58 AM
Too much oil is just as bad as too little. As the oil level in the pan rises, the crank counterweights whip it into a froth. While that may look good on your latte, it does a very poor job of lubricating the engine bearings.
Old Oct 12, 2020 | 05:12 PM
halffasted's Avatar
IMO - Olds has always been a trifle slow in oil return. I helped it out by running a grinder w/carbide burr down the oil path below the valve springs and rounded and
smoothed the drain hole going from head back down into block. If able I would also grind a lot of bumps and slag in the lifter gallery and remove excess between the lifter bosses in the block. Early engines were the worst, that's why pulling a valve cover produced a mass of sludge (coupled with lack of early detergent oil). Every little bit helps.
Gary M
Apr 5, 2017 08:05 AM
scooter123
Mar 5, 2014 11:23 AM
Tony72Cutlass'S'
Sep 23, 2012 05:44 AM
Tedd Thompson
Jun 14, 2012 07:28 PM
