Does anyone know what pulleys a 68 442 without air should have? I have a KE on the water pump, aKH double pulley on the p/s, and a 6.5" double on the crank. The alternator belt from inline tube fits ok but the p/s belt is way too small.
The 399403 PS pump pulley is a single groove, 5.75" diameter pulley, code "KG", so that's wrong on your car. The fan and crank pulleys should be 399401 "KE" and 399402 "KB", respectively. The PS pump belt should be 44".
