Spark Plug Gap Closing
Old April 7th, 2019, 11:11 PM
hurst1's Avatar
Good evening.
Went to check plugs today and a couple things I have questions on. All 8 gaps on the plugs moved closer. I originally gapped them at .040 and I noticed that the gap closed up. What causes this to happen?
Also all plugs are clean except plug no 7. This plug has a soft white covering on tip. What would this be a sign of?
73 olds omega with 350.
Thanks Bill
hurst1 is offline
Old April 8th, 2019, 05:12 AM
I would think either the plugs are wrong for the application (tip is too fat into the combustion chamber) or there is a bunch of carbon on the piston. Either may cause contact with the piston and close up the gap. Other than that, I’m out of ideas.
matt69olds is offline
Old April 8th, 2019, 07:35 AM
It may help if you posted which plugs you have.
Fun71 is online now
Noel Anderson
February 27th, 2021 03:54 PM
madmax442
Non-Olds Engines
June 3rd, 2015 04:27 PM
chasman414
October 30th, 2014 03:15 PM
IZAOLDS
May 31st, 2011 12:52 PM
ralsy
August 27th, 2010 01:07 AM
Quick Reply: Spark Plug Gap Closing
