Spark Plug Gap Closing
Old Apr 7, 2019 | 11:11 PM
hurst1's Avatar
Good evening.
Went to check plugs today and a couple things I have questions on. All 8 gaps on the plugs moved closer. I originally gapped them at .040 and I noticed that the gap closed up. What causes this to happen?
Also all plugs are clean except plug no 7. This plug has a soft white covering on tip. What would this be a sign of?
73 olds omega with 350.
Thanks Bill
Old Apr 8, 2019 | 05:12 AM
I would think either the plugs are wrong for the application (tip is too fat into the combustion chamber) or there is a bunch of carbon on the piston. Either may cause contact with the piston and close up the gap. Other than that, I’m out of ideas.
Old Apr 8, 2019 | 07:35 AM
It may help if you posted which plugs you have.
Noel Anderson
Feb 27, 2021 03:54 PM
madmax442
Non-Olds Engines
Jun 3, 2015 04:27 PM
chasman414
Oct 30, 2014 03:15 PM
IZAOLDS
May 31, 2011 12:52 PM
ralsy
Aug 27, 2010 01:07 AM
