69 olds 350 timing issues
Old February 25th, 2019, 01:43 PM
vistanut's Avatar
hi all just installed a new timing chain and gear,crank sprocket on my 69 vista ran # 1 cyl to tdc center allinged the marks put it back together and tried timing light it will not run where its supposed to tried advance 1 tooth on distributor and back 1 tooth no luck #1 cyl lines up on the distributor at a loss im running the stock dist but replaced the points with a pertronix 1181LS ignition any suggestions from everybody would be helpful
vistanut is offline
Old February 25th, 2019, 07:40 PM
Is it firing at all on your timing light? Start with getting #1 cylinder at tdc and then stab your distributor. The rotor will be pointing to #1 wire on the cap, then wire ccw 18436572. Make sure there is power to the coil and remove the filter cap. If you have a tach, leave it disconnected until you get the engine running.
oldcutlass is online now
Old February 26th, 2019, 08:30 AM
FStanley's Avatar
got back to basics
1. Make sure you are on the #1 compreson stroke , then make sure TDC of piston lines up with the timing mark on Haronic balancer. just to make sure you aren't 180 Deg off..
2. Make sure plug wires are correct on distributor cap. firing order, make sure you have spark.
3. Find where #1 wire is on Distributor cap, and mark below where this is on the distributor body.
4. Pull distributor out if need be, and align rotor were #1 mark is on the distributor body, or maybe just a pinch before it.. NOTE Olds V8 330-455 distributors run counter clockwise.
5. make sure carb has fuel and choke is closed.
Good luck
Fred
3.
FStanley is offline
Shawnk111
July 12th, 2019 01:06 PM
LoganMiller68
March 31st, 2015 04:57 PM
Macadoo
January 11th, 2014 11:49 AM
getitmann
July 12th, 2012 06:58 PM
Gunfreak25
December 7th, 2010 08:23 AM
Quick Reply: 69 olds 350 timing issues
