67 442 coupe body mount bushings
Old Jun 10, 2018 | 11:28 AM
NotDads442's Avatar
I ordered a 10 piece kit from Inline tube and have the FSM. It states in the FSM that the #4 and #5 spots are to be the rubber pucks with no bolts. However in my pictures I took during disassembly #4 by where the rear lower control arm bolts to the frame I have a mount that took a bolt and #5 around the suspension spring was a puck.
Also the mount in the middle of the door has a smaller frame hole than the rest in the frame and I had to leave it vacant because their kit sucks.
I also had 8 mount bolts and large washers with 8 bolts being the same length and 2 longer bolts. Do these longer bolts have washers? If they do I misplaced them. Where do the two longer bolts go? Because now I have bolts and bushings at 1,2,6 and 7 positions and just bushings at 4 but the FSM says #4 shouldn’t be there. Again I would have put them at position 3 but the bushing would not fit in the factory recess in the frame.
Rvsmith5
Jul 26, 2018 06:50 PM
Tugla
Jan 22, 2018 09:05 AM
reffett brandon
May 14, 2016 09:15 AM
CuttyShark
Jul 25, 2015 01:25 PM
Redog
Nov 30, 2007 11:55 AM
