Clutch to flywheel bolts
Old March 30th, 2017, 04:21 PM
Bfg
Bfg's Avatar
Need to replace the clutch to flywheel bolts on my 65 442. The original bolts had a shoulder on them. The replacement bolts from Motorcity were threaded all the way. Would there be a problem with these? They said they were as originals.
Bfg is offline
Old March 31st, 2017, 07:26 AM
Run to Rund's Avatar
The purpose of the shoulder, as on Mr. Gasket bolts, is to positively locate the pressure plate for balance. The shoulder fits snugly into the holes in the plate and flywheel.
Run to Rund is offline
Old March 31st, 2017, 07:43 AM
Bfg
Bfg's Avatar
Ok, thanks. I'll get mr. Gasket bolts.
Bfg is offline
Old April 1st, 2017, 08:25 AM
Mr. Gasket #910
Old April 1st, 2017, 08:45 AM
Junkman's Avatar
If you care to go for the extra money, have both the flywheel and the pressure plate balanced as a unit. Many times, after both have been surfaced, the balance is off, enough to cause you a vibration. It is a lot easier to do it now, then to have to take it apart later on due to a vibration that you can't seem to figure out.
Junkman is offline
nolabigdawg
October 25th, 2014 11:50 AM
Beau Dirt
April 28th, 2012 02:21 AM
Chesrown 67 OAI
March 14th, 2012 06:18 AM
Eddie Hansen
March 23rd, 2010 11:49 AM
Quick Reply: Clutch to flywheel bolts
