350 seems a lil crooked -gbody
Old Aug 13, 2016 | 06:55 AM
88 Cutty Classic's Avatar
Dropped the 350 rocket in my monte SS yesterday. Used the 307 frame pads and olds engine mounts. Bolted the frame pads in the same location they were on the cutlass frame but the engine seems cocked to the drivers side just a hair. Iike 1/4 to 1/2 inch. The trans mount has 3 holes and it doesnt want to bolt to the middle hole, only the side hole.
Is this normal? Did i do something wrong? Words of wisdom?
Old Aug 13, 2016 | 07:27 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Double check the frame mount position. Both mounts are in good shape? I would loosen everything, including frame mounts and line up your trans mount first. It may take some shifting with bars to get it in straight.
Old Aug 13, 2016 | 10:04 AM
Brackets are all correct. On the correct sides. The mounts easily came down over the brackets and bolts went in easy.
Old Aug 13, 2016 | 10:09 AM
Here is some pics
Old Aug 13, 2016 | 06:30 PM
svnt442's Avatar
There is always the possibility that the frame is not 100% straight.
Old Aug 14, 2016 | 06:59 AM
Originally Posted by 88 Cutty Classic
Here is some pics
Can't really tell much of anything from those photos. If you really care about levelness, block the frame using a level across the frame rails to make sure the frame is completely parallel to the floor. Now put that level across the carb flange. Is the engine level or not?
Seff
28
May 15, 2014 08:37 AM
76olds
25
May 7, 2014 09:47 PM
EightyEightCut
May 1, 2013 07:48 PM
viper771
Feb 15, 2013 07:38 PM
Homestar
May 4, 2011 01:14 AM
