Fluids for 72 cutlass
Hi everyone. Just wondering what type of trans fluid to use in my 72 TH350? And how many quarts should it take if it was drained? Also how about brake fluid type (I have an aftermarket disc/drum setup inline tube) and amount and power steering fluid and amount? I know engine oil should have the zinc additive. Any particular brand you recommend? Any other fluid advice? Thanks so much!
Chris
Chris
Chris
Chris
In addition to my trans fluid question above, I was told by someone NOT to use synthetic motor oil or trans fluid in my stock original engine and trans. Thoughts?
thanks
chris
thanks
chris
When I re-did my brakes, I used silicone fluid. It's been in there for ten years (but admittedly not that many miles) with no problems.
This is what I just put into the transmission on my '78 Toronado. Note what it says on the back label regarding compatibility.
This will work fine in a '72 GM car.
piersonhouse
July 9th, 2016 01:50 PM
