quadrajet Qjet port identification and whats this ?
Old May 26, 2016 | 03:34 PM
RetroRanger's Avatar
72 Olds CS
im ready to bolt my carb on but i wanted to make sure i IDd the ports correctly.
The front view shows what I think the ports are. PLease correct me if Im wrong
The back view has two ports im not sure what they are? I think #2 is related to the hot air choke (i installed an E choke) and #1 IDK what it is for. if i dont need these 2 on the back can (and should) i just cap them off?
thanks for any help
Old May 26, 2016 | 03:50 PM
Yep, those look right.
The only thing I can't say much about is the rear-facing side -
One of those is definitely the inside-air-cleaner air feed for the hot-air choke, but I can't think of what the other one is for.
Old May 26, 2016 | 05:56 PM
I believe #1 should be the vent line from the TCS solenoid if this is for a 71/72. #2 is for the air cleaner. The Hot Air choke is a metal line that goes to the choke coil spring housing.
Old May 26, 2016 | 05:59 PM
Ah, yes, TCS. Very logical.
All of the Olds carburetors I've messed with over the past few years were 1970 or earlier, so I hadn't seen this.
Old May 26, 2016 | 06:09 PM
One side of the hot air U pipe goes to the choke housing; the other side goes to the port on rear of the air horn so it pulls filtered air from under the air cleaner. There is a short section of rubber hose that connects the metal pipe to the nipple on the carb.
Old May 26, 2016 | 08:17 PM
72 Olds CS
ok very good info thanks guys.
It is for a 72 application kinda its my 72 CS w a 70 455, and IIRC the carb is a 72 as well, but no TCS and no hot air choke, so i will block those two off.
90customcruiser
Jan 26, 2013 11:57 AM
MN71W30
Oct 17, 2011 09:03 AM
dman0712
Dec 6, 2009 08:02 PM
23109 E.O.S.
Apr 6, 2009 04:58 PM
mitsudave
Nov 17, 2007 07:49 PM
