Would you use those sealer pellets on new cooling system?
I'm talking about these drop in pellet deals. Probably made by Bar's Leaks, but who knows.
GM, and likely others, for years used to toss a couple of these into the system prior to first fill. Probably still doing it today. Probably everyone else did it or is still doing it today.
If you rebuild your engine, install a new radiator, water pump, etc., effectively renewing the system, would you toss a couple of them in as well? I know they did/do it more for insurance because getting them out on the transports as quick as possible without having to fix stuff was the goal, but still. I'm kinda on the fence about it. For one, it obviously couldn't hurt or they wouldn't do it, but two, if you build it right since we don't mass-produce, it shouldn't leak anyway. TBH, I've only used that stop leak once for a pinhole seep far away from home, and although it worked, it always bugged me. I try to avoid it as much as possible.
This morning, I was looking at the 71 PIM and saw that note again about putting a couple in the radiator and jogged my memory.
Opinions/thoughts?
Opinions/thoughts?
Those were required and very common “preventive maintenance” on the early Cadillac 4100 engines.
They do work, and if used properly they won’t hurt anything. They obviously will do nothing for an engine with serious cooling system problems.
You were military. Last time I looked Bar's Leaks carried a mil-spec ID number.
As a owner of many 85 Seville and one 85 Eldo.with the Cadillac 4100. Which had an aluminum block with iron heads, With the wrong head gaskets up to the late 1984 4100, It was to seal the head gasket from leaking. not for the radiator. Radiator was the delivery system to seal the head gaskets. Near the end of the 1984 line 4100 (after Vin # that i have someplace) they received the correct gasket for dissimilar metals. I would not use in any car other than late pre 1984 4100.
71CutlassSupreme
July 3rd, 2011 06:38 AM
