Windshield wiper linkage restoration
Old Jun 20, 2017 | 07:59 PM
servexcell's Avatar
Is the parts available to restore the linkages. has anyone done so?
Thanks Bruce
Old Jun 20, 2017 | 08:46 PM
Charlie Jones's Avatar
Phantom Phixer
Here's one ;
http://www.wiperman.com/
Old Jun 21, 2017 | 07:01 AM
oldspackrat's Avatar
I have several good 1968-72 wiper transmissions here in Indy.
Call me?
Scott
317-727-7041
Old Jun 21, 2017 | 02:57 PM
oddball's Avatar
You can mostly disassemble, clean and lube the parts. Some of the joints can't be disassembled, but you can inject lube. If a part is completely worn out then you may be best off buying a better original unit.
Old Jul 4, 2017 | 09:14 PM
servexcell's Avatar
It seems like the joints are a ball and socket type,They are bolted and i think they have copper sleeves. Does anyone know were to get parts
thanks Bruce
Old Jul 4, 2017 | 11:08 PM
Phantom Phixer
thanks Bruce
Bruce , I can only assume that we are talking about a '68 Cutlass or 442 ?
This wiper linkage was crimped together at the joints , and was serviced only as a complete assembly . There was a left and right side . Some models had recessed park {disappearing} wipers. The left side had a different assembly.
Everything from the round part that the wiper arm attaches to , down to the wiper motor .
I found the following;
I found the part numbers here;
http://wildaboutcarsonline.com/membe...sher_Parts.pdf
4918758 for RH side
4918620 for LH side (without recessed park)
Then I took those numbers to GM partswiki ;
http://www.gmpartswiki.com/getpage?pageid=50762
and found out that that those same parts also fit '68 thru 72 Chevelle .
I googled '68 Chevelle wiper linkage and found this ;
http://www.jegs.com/i/Performance-Tr...yABEgKasPD_BwE
Old Jul 5, 2017 | 06:48 AM
I have several complete wiper transmission assemblies, $35.00 plus shipping.
Old Aug 24, 2017 | 05:29 PM
servexcell's Avatar
Sorry for the belated response guys. Reaaly appreciate the help. I think you can maybe pirchase bushings for the linkage.
Bruce
507OLDS
Mar 19, 2014 08:17 PM
STLCRZY
Nov 4, 2013 03:22 PM
miked
Aug 5, 2013 03:15 PM
ztim
Dec 23, 2006 04:53 AM
