What is it for??
Old Dec 15, 2019 | 06:55 PM
55oldsholiday's Avatar
What is it for??
Hello..
I am new to my recently inherited Oldsmobile... i have a question regarding the copper pipe coming out of my firewall... what is it for? And why would it not be hooked up?
thanks
Old Dec 15, 2019 | 07:10 PM
Charlie Jones's Avatar
Phantom Phixer
It is for the heater core .
Simple answer is that probably the heater core or it's valve were leaking coolant , and the heater was probably not really needed .
So it was disconnected rather than repairing it .
don71's Avatar
same but different
It is the heater core for heating the interior cabin. Its not hooked up because it most likely leaked into the interior at some point in the car's life.
It happens in the life of older cars. The easy way out for some folks is to just unhook it, as replacing it is often a pain in the tail for some.
Old Dec 15, 2019 | 08:26 PM
coldwar's Avatar
It is a Ranco or Harrison heater control valve - It regulates flow of coolant to the heater core controlled by a cable operated dashboard control - They leak coolant in the interior or valve gets stuck - Frequently bypassed with the result being full-time heat.
Order a replacement from Fusick.
Old Dec 15, 2019 | 08:45 PM
Tedd Thompson's Avatar
They are a pain to replace and have to come out from behind the air box on the inside passenger side. What ever you do don't throw it away because they haven't repoped them in a long time and who ever does your rebuild will need it as a core or charge you according. You may find one somewhere NOS but they are rare ...Tedd
Old Dec 15, 2019 | 09:28 PM
redoldsman's Avatar
Proud Viet Nam Veteran
You can occasionally find them on ebay but they are expensive. Fusick does offer a rebuilding service. It is a pain to remove. I replaced the one on my 54 with one for a 53 with the only difference being the way the tubes are placed. Getting the heater box out is a pain. GM used some stuff like tar back them that literally takes a small crowbar to pry loose. And then there is always the illusive nut you can't find on the firewall. Be prepared to replace or at least get your heater core rebuilt. This is not a job you want to do twice.
Old Dec 16, 2019 | 02:26 AM
Thanks everyone for the information! I guess I will think about doing this as the car will only be driven in the summer.
SanTan Devil
Aug 25, 2025 03:53 PM
kbdecatur
Nov 8, 2017 02:13 PM
Mak
Jul 18, 2011 02:09 AM
bigfun64mo
Jul 12, 2009 11:28 AM
Chris L.
May 28, 2004 09:44 AM
