Whaaaat?
Old Apr 16, 2016 | 06:51 AM
Copper Nine Eight's Avatar
Whaaaat?
So yesterday I did my oil change and because whenever I have to get on the freeway, my car starts hesitating to pick up speed. I figured it was the fuel filter. So I changed that as well. My car no longer hesitates. But now my check engine light came on. It wasn't on before. And it only cuts on when I start driving. When I'm sitting at idle, it doesn't come on but about a minute after I start driving, it cuts on. I know this question is pretty broad but what do you guys think is the problem? 1985 Delta 88.
Sorry for the length haha!
Old Apr 16, 2016 | 07:18 AM
The problem is that we can't help you until you tell us which code is causing the CEL to come on. Read the code(s) using either a scan tool or a paper clip.
Old Apr 16, 2016 | 09:59 AM
Also, the problem is almost definitely with whichever hose you bumped while installing the fuel filter, so once you've got the code, that will probably help you find the hose.
