Water pump 61 dynamic88
It's easy enough if you know what you are doing .
If you want to know what you are doing , get a 1961 Oldsmobile service manual ;
https://www.ebay.com/itm/1961-OLDSMO...YAAOSw-0xYOQM7
Just did mine yesterday. Very easy. Drain coolant with petcock on radiator, take off fan and shroud behind it (don't forget the belts), then the water pump will be there. 6 bolts to remove that and let the rest of the coolant drain. Clean remnants of old gasket off with razor blade and then put the new pump/gasket on and reverse the process to put back together. Also I used this time to replace the thermostat and gasket, I'd recommend that, too.
ReallyWildStuff
Non-Olds Engines
February 21st, 2018 02:43 PM
