water pump / 2 groove pulley combinations
I have a 68 cutlass s that shreds the alternate belt.
The issue is that the alignment with the water pump pulley is way off.
Also, it has a incorrect 3 groove pulley on when I bought the car.
I have ordered 2 different 2 groove pulleys and neither of them line up the belts correctly.
How to I find out what water pump I have and what water pump pulley I need.
There was a post that stated that Olds used many different pump/pulley combinations.
Is that listed anywhere?
Thanks in advance.
Thanks in advance.
If your trying to keep it original there are reference pages that show various combinations with different options the car may have come with. I think members here can help you figure out what you need. What length of water pump do you have? Do you have AC? Do you have PS? John
