Valve cover gaskets questions- '68 442
Old December 26th, 2010, 09:45 AM
JBrooks's Avatar
The driver's side valve cover gasket is leaking on my '68 442 (400 cubic inch motor). It drips onto the exhaust manifold and causes a fairly strong odor.
NAPA auto lists a series of valve cover gasket materials at various price points.
My questions:
1) I would appreciate advice on which gasket material to purchase?
2) Also, should I use the "blue" gasket sealing material on the gasket?
3) Does anyone have the torque specifications for the valve cover bolts?
4) Finally, any advice on moving the air conditioner compressor enough to get at all the valve cover bolts and remove? I do not want to loose the A/C coolant fluid.
Thanks for any advice on doing this correctly.
Jim
JBrooks is offline
Old December 26th, 2010, 10:24 AM
I like neoprene gaskets. The A/C compressor can be completely unbolted so long as you don't disconnect the hoses. Leave them attached and move the compressor to the side.
joe_padavano is offline
Old December 26th, 2010, 11:37 AM
My442's Avatar
Thumbs up
The absolute best V/C gaskets are FelPro PermaDry.
They have a plastic frame with an embedded O-ring seal.
Expensive, but last forever and don't leak.
And, they require no sealer.
My442 is offline
Old December 26th, 2010, 01:32 PM
same but different
don71's Avatar
I agree and they are totally reusable....over and over again.
don71 is offline
Old December 26th, 2010, 03:58 PM
old442's Avatar
I got neoprene gaskets for a diesel application , a lot thicker and never had a leak since I installed them 4yrs. ago . They to can be reused also.
old442 is offline
Old December 26th, 2010, 05:20 PM
JBrooks's Avatar
Thank you for all of your advice on the gaskets and moving the A/C compressor..
It is very much appreciated.
A final question regarding torque specifications?
Thanks again.
Jim
JBrooks is offline
Old December 26th, 2010, 05:33 PM
The only thing I can say is to give a general warning that applies to all stamped steel covers (valve cover, engine oil pan, trans. oil pan, etc.), and also to soft flanges, like aluminum carbs:
Tighten the bolts less than you think you should.
The typical kid-at-the-gas-station / weekend mechanic tightens them to much, deforming the lip of the cover near the bolt holes, and leaving the areas between them to loose, thus guaranteeing future leaks.
MDchanic is offline
Old December 26th, 2010, 06:23 PM
Randy C.
rcorrigan5's Avatar
The Chassis Service Manual says 7 ft lbs for valve cover bolts.
Randy C.
rcorrigan5 is offline
Old December 27th, 2010, 03:16 AM
... and that's about as much as tightening a screw with a screwdriver.
MDchanic is offline
Old December 27th, 2010, 06:33 AM
Lady72nRob71's Avatar
And if you do not have a torque wrench, just tighten them with a nutdriver, alternating amongst the bolts as you tighten them.
There is also the Permadry-plus gaskets that are all blue silicone or something. I used one on my Ford and never had a weep! My torque wrench would not go down that low so I used a nutdriver.
Just be sure to hammer the valve cover sealing surface flat first, as often the areas around the holes are warped from over torquing over the years to try to stop leaks.
Lady72nRob71 is offline
Old December 31st, 2010, 01:12 PM
jag1886's Avatar
I always use cork gaskets and silicone them to the valve cover and install them dry on the head side, been doing it that way for 30 years works every time. You can also remove the valve cover several times without hurting the gasket.
jag1886 is offline
Old December 31st, 2010, 03:17 PM
Run to Rund's Avatar
I've been able to reuse Mr. Gasket 5875 coated cork if I use oil or grease on both sides, hammer flat the bolt areas of the valve covers, and don't overtighten them. I make sure they go on the same head and valve cover each time, and wiggle the cover to be sure the gaskets are "seated." I have also used the rubber gaskets over. Might try those Fel Pros some day.
Run to Rund is offline
Old December 31st, 2010, 04:35 PM
Rickman48's Avatar
X2 on the cork - I use Weatherstrip adhesive on the V/C side, and wheel bearing grease on the head side - works for me!!
Rickman48 is offline
Old June 18th, 2011, 06:17 AM
Chesrown 67 OAI's Avatar
Where can I buy these? Is this an obsolete number? Cant find this number listed at any parts store via Google?
Chesrown 67 OAI is offline
Old June 18th, 2011, 03:48 PM
same but different
don71's Avatar
It looks like these are no longer available. I checked Summit,Rock Auto and Oriellys..... Nothing.
don71 is offline
Old June 18th, 2011, 03:54 PM
I noticed they were discon'ed also.
The regular rubber Felpro VC gaskets are still available at many places and I would recommend those over the cork ones. The rubber ones do not require sealer and are reusable.
Old November 29th, 2022, 07:51 AM
Oldzskool's Avatar
Valve cover gasket
got a part number?
Oldzskool is offline
Old November 29th, 2022, 08:12 AM
This thread is over a decade old...
And if you read through the posts, you'll see that they were discontinued even then.
Old November 29th, 2022, 08:22 AM
Oldzskool's Avatar
I only graduated high school but yeah I can read dates. Why would I read through a decade old thread?
Old November 29th, 2022, 08:32 AM
Why would you respond to one? And in any case, since you started reading it, you would have found the answer to your question.
Old November 29th, 2022, 08:49 AM
Oldzskool's Avatar
I responded to it because I wanted a part number that I could enter on eBay or this forum.
Old November 29th, 2022, 08:02 PM
bccan's Avatar
FelPro PermaDry Plus VS13403T. The “T” is the key, do not confuse with”C” or other suffixes. They’re long since discontinued but do occasionally pop on eBay. Best VCGs made for Olds but now extinct.
On this sight, search “Perma dry” where you will find some good discussion on other choices that are commonly available and people’s opinions of them
bccan is offline
Old November 30th, 2022, 04:48 AM
Oldzskool's Avatar
Gaskets
hey man really appreciate the information.
Old November 30th, 2022, 06:29 AM
Oldzskool's Avatar
VS13403T I guess I’m not the only to RESPOND to decade old threads.
Old November 30th, 2022, 06:59 AM
bccan's Avatar
Just trying to help you out. Subject is relevant even if it’s an old thread, VCGs are an ever changing dynamic for our old cars. One would think that with all those bolts the gasket would be inconsequential but that just isn’t the case.
bccan is offline
Old November 30th, 2022, 02:27 PM
Oldsmobile enthusiast
s i 442's Avatar
I use cork, and lightly silicone it to the head.
I tried the rubber ones once and it was like wadding up plastic baggies and using them as a gasket.
s i 442 is offline
Old November 30th, 2022, 03:58 PM
Wow, way different experience than I had. I used the thicker (11/64") Fel Pro rubber gaskets VS50259R. They worked exceptionally well.
Fun71 is online now
Old December 20th, 2022, 09:59 AM
omy442's Avatar
I use cork, but after 30+ yrs, I still remind myself to gently snug the bolts. Too much and overtighten, gasket collapses, and leaks are guaranteed.
I battled for years with moroso tall valve covers leaking and tried every type of gasket. When I took off 2x4 intake and went back to stock under the hood, I went with cork and stock valve covers.
I'm sure others will chime in about absorption characteristics and heat and cooling cycling of cork vs other types of gasket material.
Mader
omy442 is offline
Old December 20th, 2022, 10:10 PM
oldolds88's Avatar
make sure your drain holes are clear, or it will be ongoing problem
oldolds88 is offline
Old December 23rd, 2022, 07:22 AM
Ozzie's Avatar
Sometime spreaders can help.
Ozzie is offline
stephenallee13
September 20th, 2021 10:12 AM
W-27
March 11th, 2021 09:16 AM
v8al
May 18th, 2019 06:41 PM
Ddbord
April 12th, 2012 06:50 PM
Ddbord
August 12th, 2010 01:17 PM
Quick Reply: Valve cover gaskets questions- '68 442
