Vacuum controller
Vacuum controller
I have a quadrajet 4 b. On top a 455 1971 cutlass. How dow i hook up the vacuum controller that sits behind the oil filler tube. It has a port on top and three on the side. Im sure one goes the vacuum advance but after that..whew
The three ports on the side of the TVS are labled M, D, and C. The M port goes to direct manifold vacuum. The D port goes to the distributor, and the C port goes to the ported vacuum port on the carb. The top port goes to a vent port at the top rear of the carb.
Of course, unless you care about total correctness, most folks simply eliminate the TCS system (and the associated TVS) and connect the vacuum advance to manifold (or ported) vacuum. I don't want to start a manifold vs. ported vacuum flame war here, however.
oddball
December 9th, 2012 07:11 AM
Dan Wirth
December 2nd, 2011 01:55 PM
