Vacuum controller
Old Nov 5, 2010 | 11:08 AM
TRAIN RACING's Avatar
Vacuum controller
I have a quadrajet 4 b. On top a 455 1971 cutlass. How dow i hook up the vacuum controller that sits behind the oil filler tube. It has a port on top and three on the side. Im sure one goes the vacuum advance but after that..whew
Old Nov 5, 2010 | 12:55 PM
That "vacuum controller" is actually called a Thermal Vacuum Switch (TVS) and it's part of an early emissions control system called Transmission Controlled Spark (TCS). The purpose of TCS was to reduce NOx emissions by disabling vacuum advance in all gears except high (third on an AT, for example). The electrical terminals on the top of that TVS are contected to a pressure switch in the transmission that enables vacuum advance in high. At other times the line to the distributor is blocked and the hose is vented. The "thermal" part of the TVS comes from the fact that it is screwed into the coolant crossover on the front of the intake. Disabling the vacuum advance can cause the engine to overheat under prolonged idling or stop-and-go conditions. The TVS senses that and connects the vacuum advance directly to manifold vacuum if that happens. Normally the advance operates off ported vacuum.
The three ports on the side of the TVS are labled M, D, and C. The M port goes to direct manifold vacuum. The D port goes to the distributor, and the C port goes to the ported vacuum port on the carb. The top port goes to a vent port at the top rear of the carb.
Of course, unless you care about total correctness, most folks simply eliminate the TCS system (and the associated TVS) and connect the vacuum advance to manifold (or ported) vacuum. I don't want to start a manifold vs. ported vacuum flame war here, however.
Old Nov 5, 2010 | 01:02 PM
Danny Boy's Avatar
1972 98 & 1984 H/O
vacuum controller hoses
I hope this helps
File Type: pdf
oddball
Dec 9, 2012 06:11 AM
beepac98
Ninety-Eight
May 15, 2012 05:36 PM
Dan Wirth
Dec 2, 2011 12:55 PM
69350rocket
Dec 27, 2010 02:15 PM
Jolly Green
May 17, 2008 05:04 PM
