Torque specifications
Replacing quarter window bottom roller and was wondering if anyone knows the torque specifications of the nut/washer that holds the bottom roller to the glass portion.
It's a German torque spec...gooden-tite. Seriously, its likely inch pounds. Snug with a dab of blue removable Loctite so you don't stay awake at night will do it. Use a 1/4" drive ratchet if you don't have a torque wrench. It will prevent hairy knuckle over torque.
