tick tock tach need help
Old Apr 22, 2014 | 06:40 AM
akins2000's Avatar
Hello I purchase the tick tock tach and right now I have a after market tach and the HEI msd 6AL digital box with coil on my 1972 cutlass right now and it's working great. Since that is working fine, can I just us the same wires off the after market Tach without the msd adapter?
Old Apr 22, 2014 | 08:37 AM
allyolds68's Avatar
I know this won't answer your question but everyone here will tell you yes and if you call MSD they will tell you that you need the adapter.
Old Apr 22, 2014 | 08:51 AM
GAOldsman's Avatar
"Car"mudgeon
In my experience some tachometer's will work with the digital box and some will not. Your best bet is to try it and if doesn't work, you'll have to get an adapter. If it is wired up correctly, it won't hurt it to try.
Old Apr 22, 2014 | 09:53 AM
If your current after market tach works then your tic tock tach should work also.
Old Apr 22, 2014 | 12:06 PM
Correct. The factory tach uses the same type of tach signal as the aftermarket tach.
Old Apr 22, 2014 | 01:56 PM
allyolds68's Avatar
Just so you all don't think I'm crazy here's my question to MSD:
http://www.msdignition.com/forum/showthread.php?t=19322
The Cliff Notes version:
Will an original 68 Oldsmobile Rallye Pack tach work off the tach lead on the 6AL without adapters. If not, what is required?
Thank you
Mike
Originally Posted by msdtech1955
8920 tach adaptor:
yours would require the voltage trigger hook -up.
Attachment 2897
http://www.msdignition.com/product.a...723&terms=8920
Old Apr 22, 2014 | 02:48 PM
GAOldsman's Avatar
"Car"mudgeon
I have an older aftermarket tach that works well with my HEI but would not work with the MSD 6AL box I have in my coupe. I have a newer aftermarket tach in my coupe that works fine with the MSD 6AL box without the adapter. I don't know the difference between the two but I do know my experience.
Koda
Dec 3, 2013 08:50 PM
455 Olds 442
May 9, 2013 03:05 AM
442buyer
Jan 7, 2012 06:43 PM
72442
Sep 23, 2009 08:43 AM
442buyer
Mar 31, 2007 06:46 AM
