tach
Old Jan 2, 2022 | 01:56 PM
glent's Avatar
Glent
tach
I saw a tach retro for a 71 It was a bolt on in the clock location No it is not tic toc set up Does anyone have any information on something like this. it has been years ago when I saw this.
Old Jan 2, 2022 | 02:39 PM
There are multiple posts with pictures of a standard tach installed in the clock pod opening. My car has a Sun Super Tach II in the opening. Looks a lot like this:
Have a look at the pics in this thread:
https://classicoldsmobile.com/forums...-ideas-119806/
Old Jan 2, 2022 | 03:19 PM
RetroRanger's Avatar
72 Olds CS
Gm sports salvage or a similar name used to sell a tach that looked like the tic toc tach but no clock just a tach to repkace a clock or clock blank.
but what kenneth posted is a good choice too……somebodies gotta clean their sport wheel!
Old Jan 2, 2022 | 04:46 PM
4speed455's Avatar
The GM Sports tach only is no longer being made.
Old Jan 2, 2022 | 04:56 PM
There are multiple posts with pictures of a standard tack installed in the clock pod opening. My car has a Sun Super Tach II in the opening. Looks a lot like this:
Amen. I did the same. Took a blank. Cut it out. Super Tach even with it's lense. Perfect fit. Reliable too.
Old Jan 3, 2022 | 05:47 AM
Other than the now out-of-production tach from GM Sports Salvage, there is no "bolt in" aftermarket tach for the clock pod. As shown, people have fabricated mounts to adapt them.
Old Jan 3, 2022 | 06:29 AM
VC455's Avatar
Barely Registered
You could have a local instrument shop make one from a clock.
Old Jan 3, 2022 | 11:35 AM
There are so many of those tachs in 70-72 cutlass/442 most people would think they came factory.
Old Dec 27, 2022 | 06:35 PM
Toms cutlass's Avatar
Where did you have this made?
Old Dec 27, 2022 | 07:36 PM
VC455's Avatar
Barely Registered
Tom, an instrument shop in Bloomington (Minneapolis) MN made it for me.
After the owner sold the shop, they lost their mojo.
Find a local shop and ask to see some before/after restoration pictures. You can judge from that if they have the capability you want.
National shops doubtless exist that can do this work. Look up some and ask the before/after question.
My instructions to the Minnesota shop were to use the same font and arrangement as the speedometer. The 6000 range was half the speedometer range. And it avoided the typical, unrealistically-high range that impresses only the ignorant and makes accurate reading more difficult.
A good shop will send you a pre-production color layout so you can ask for tweaks if needed.
Best of luck, and please post what you come up with.
Gary
Old Dec 27, 2022 | 08:11 PM
Thanks very much for your detailed reply, Gary. Your tach looks OE. The detail and font are perfect, and agree with your choice of RPM max range. This is a great alternative to blank, clock only, or after-market tach in that location of the dash.
Bowtie-Bri
Jan 7, 2018 12:18 PM
firefrost gold
May 30, 2014 02:00 PM
Wbland
May 18, 2013 06:21 PM
Wbland
May 18, 2013 03:25 PM
mmurphy77
Jun 22, 2010 05:59 AM
