Switching from 350 to 455
Old March 4th, 2009 | 08:01 PM
shopaholic07's Avatar
Will the existing manifolds work when switching fro the rocket to a 455 or will they have to be changed?
Old March 4th, 2009 | 09:01 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
intake manifold will not swap over.
exhaust manifolds will.
Old March 4th, 2009 | 09:07 PM
64Rocket's Avatar
Yes, they will fit, if you have single exhaust you will have to rework the crossover.
The main thing is they are much smaller and restrictive. If you have dual exhaust you will have some align problems.
Gene
Old August 2nd, 2009 | 06:05 PM
70_Convert's Avatar
I replaced the 350 Rocket in my 70 convertible with a 455, 68 police intercepter kit, headers. Dropped right in.
Old August 3rd, 2009 | 08:03 AM
citcapp's Avatar
Don't use the 350 exhaust manifolds on the 455 way to small and restrictive. Use headers of W & Z headers. You can find them on e-bay
Old August 4th, 2009 | 08:19 AM
While they will physically bolt up, in addition to being overly restrictive, the other reason not to use SBO manifolds on a BBO is that the exhaust flanges are in different locations. The BBO manifolds (at least on the A-body installations) are designed so that the exhaust flange is at the same location as it is on the SBO. Using the shorter SBO manifolds on a BBO will put the flanges higher and further outboard, which makes custom pipes mandatory.
Wyze
May 14th, 2010 01:29 PM
cutty
December 16th, 2008 03:46 PM
442scotty
September 16th, 2008 04:54 PM
geckonz08
August 7th, 2008 07:33 PM
nice72
April 7th, 2008 06:26 AM
Quick Reply: Switching from 350 to 455
