Stuck adjustable seat buckle strap
Old Nov 27, 2021 | 01:53 PM
wherlehy's Avatar
Hello Experts,
1970 Cutlass S
What is a good way to keep your original seat belts (hand adjustable belt, not the rolling retractable one on the door side) that are stuck and won't adjust.
I was thinking WD40
- but I feel that will stain the belt.
Pictures please if available.
Regards,
Bill
Old Nov 27, 2021 | 02:44 PM
Try silicone spray lube. The bar inside the buckle gets rust on it and won't move.
Old Nov 27, 2021 | 02:56 PM
The buckle cover can be pried off so you can get to the rusted parts and clean them up.
Use a small screwdriver to pry the rear face of the cover (it’s one big tab) outwards, then lift the cover off.
Old Nov 28, 2021 | 01:42 PM
rocketraider's Avatar
Oldsdruid
If you're ambitious enough to take them out of the car, a run thru some hot soapy water does them good. Sink, top-load washer, even a dishwasher will clean them. Then hang to air dry. I found it worth the effort to take them to a laundromat.
Be aware the first time the water hits them, it will turn brown or worse as it dissolves 50 yr of use.
Old Nov 28, 2021 | 03:53 PM
wherlehy's Avatar
Great idea! Besides I just gutted the interior to put a new luggage shelf in under the back window and work under the dash.
That should really clean them up!
Bill
chip-powell
May 31, 2021 03:22 PM
pav8427
Aug 22, 2019 02:58 AM
jdana24
Jun 11, 2015 09:07 PM
442oldslawyer
Mar 25, 2010 03:26 PM
fizzy55
Sep 29, 2009 10:17 PM
