What is a good way to keep your original seat belts (hand adjustable belt, not the rolling retractable one on the door side) that are stuck and won't adjust.
If you're ambitious enough to take them out of the car, a run thru some hot soapy water does them good. Sink, top-load washer, even a dishwasher will clean them. Then hang to air dry. I found it worth the effort to take them to a laundromat.
Be aware the first time the water hits them, it will turn brown or worse as it dissolves 50 yr of use.
