Still confused--350/450 swap
I've read so many different threads on motor mounts my head is spinning. Will the 455 frame mounts and engine mounts sit the 455 lower in order to create good clearnce compared to the 350 mounts? I can't seem to get a for sure answer. I'm running a former intake and big holley double pumper so I'm guessing good clearance will be an issue. Thanks.
Second, the motor mount holes on the block are in EXACTLY the same position relative to the crank centerline on every single 1964-1990 Olds V8 block. So long as the rubber motor mounts match the frame mounts, the crank centerline will be in the stock location (and the motor will be as low as it can go in the frame). If you have a tall intake, you will have to fix that problem with a scoop. You cannot lower the motor without building a new crossmember and frame.
Thank you very much how! That is the answer I was looking for. It wasn't so much other sites dating that as it was just random people commenting. Ok. So now I just need to put it in and see where we are. Maybe I will just buy one of the fancy 442 style goods with the taller scoops. Thanks again!
That is a pretty tall intake. I use this air cleaner to gain as much room under a flat hood as I can get.
http://www.ss396.com/chevelle/ATE-3907.html
Rusted72
April 10th, 2015 04:40 PM
