Steering Box Leak - 70 Cutlass
Old May 19, 2010 | 03:20 AM
Del70's Avatar
My 70 Cutlass steering box has a small leak. Fluid is coming out through a hole at top, at the front of the case. From the service manual, I think all I have to do is rotate the retaining ring and the case cover will pop off and replace the O-ring. I am having an issue finding this O-ring. The case appears to be the original Saginaw gear box. Any leads on who supplies just the O-ring seal
Old May 19, 2010 | 07:12 AM
ROCKET VAPOR's Avatar
Lance
Try calling this place.
http://www.powersteering.com/
Old May 19, 2010 | 02:50 PM
bgoble's Avatar
You may want to consider taking this opportunity to replace your steering box with one with a better turning ratio. A 92-98 Jeep Grand Cherokee steering box swap is inexpensive and a very good upgrade. The company linked in the post above can also rebuild your box to a 12:1 ratio. There is a thread on the GC swap if your interested in learning more about it. Just do a search for it.
Del70
Aug 11, 2015 04:27 AM
plonka
Mar 8, 2015 06:28 PM
wmlewis
May 17, 2012 11:37 AM
442b
Jun 30, 2011 01:05 PM
agtw31
Suspension & Handling
15
Jun 14, 2010 06:01 AM
