Sniper EFI base gasket
I am going to be installing the sniper EFI and I am wondering what folks are using for the base gasket? I am running the performer RPM intake manifold. Any help is appreciated.
Squarebore? If so, use the gasket included in the kit, or order the thicker Mr. Gasket gasket.
Make sure and sign in on the Holley forum, there is tons of user info)
https://forums.holley.com/forum.php
I believe it is spreadbore, there is a divider in the center? I thought all of the edelbrock performer rpm manifold were the same and it seems alot of people run them is why I thought Id post the question here, thanks for the reply I will check out that forum as well!
I was referring to your Sniper, they are either Spreadbore or Squarebore..
Sorry thanks
thanks yes it comes with square bore gasket I just didn’t know if that was correct I believe my performer rpm is spreadbore and didn’t know if a different gasket or modifications were needed thanks
Correct, I have been told to use the edelbrock 9265 insulator gasket in place of the 2732 and should have no issues, we will see, I’m in the process of rewiring with an auto wire harness so it may take me a few days to be ready to run! Thanks for the replies
