Similar years to the 1969 Cutlass Supreme Holiday Hartop for finding parts?
Does anyone know if 1969 Cutlass Supreme can be also found under other year models of the same car for parts finding purposes?
I'm not sure what your looking for. Some of the 1968 body parts will interchange such as fenders and rear quarter panels. Front and back windshields from 1968-72 for the Cutlass S, F85 or 442 body style. Mechanical wise a lot of parts for the 350 engine will interchange from 1968 through 72 or newer. Transmissions from several years will bolt up. Steering column from 1969 to 1973. Rear ends from 1968-72 will bolt in, as will disc brakes for the front. Steering and suspension parts from 1964-72 will bolt up. If you want specific number matching parts that will limit much to the 1969 Cutlass, F85. The items that are 1969 only are things like the bumpers, tail lights, grills, hood, trunk lid, doors, plastic lower dash, door panels.
I know there's much more but these are the items that come to mind right now. So if there's something specific your looking for post those items and people here can verify what will work for you. John
You are aware that for 1969, the Supreme was simply a trim level on the Cutlass line. You didn't provide the body style, but all 1969 Cutlii with the same body are suitable sheet metal donors. Others have correctly listed the donors for mechanical parts.
I need whatever attached the back of the headliner to the rear back center glass. I dont know if it is windlace. or hard plastic trim pieces because I dodnt get it with the car I am restoring. I have a 69 cutlass supreme holiday hardtop 2dr.
black headliner and interior.
whater pieces are need to finish up around the inside of the back glass.
I have the glass in and the headliner in already so I think its just some trim pieces and some windlace or less.
Michael 713-946-3993
It's hard rubber/plastic. I take it you mean the strip that goes around the inside of the back window. You can still get it. I got a new one for my car, which is the same thing. Think I got mine from The Parts Place.
Here you go:
IN3361T
(1968 - 1972 Cutlass/442) REAR HEADLINER WINDLACE - BLACK
$69.00
Here you go:
IN3361T
$69.00
auto doug
September 17th, 2015 07:16 AM
Oldssupreme
April 3rd, 2015 08:53 PM
coldfire
July 27th, 2013 08:00 PM
