Scissor Top Blues....Help Please
Old May 8th, 2013 | 03:25 PM
RPMRestoAndCustom's Avatar
Hey guys I'm having issues with the scissor top on my 71 Delta 88 project. About a month ago I started working on it and had it operating fine but it's getting hung up again. I replaced the switch, relay, and motor, as well as the drive cables recently. After all of that it was still getting hung up going down and up. I lubed all of the joints and then I removed the gear boxes, opened them up and blasted the insides including the gears to remove all of the petrified original grease. I re greased them and put them back together and the top was working fine. Now I've had it in the down position for about 2 weeks and it will only come up about a foot and a half and gets stuck again.
Is there something else I should be looking at? There's like a second bow slider right? Could friction from that be causing the top to get held up at that position?
1972 X code 442
September 21st, 2012 06:36 AM
White Spyder
19
July 14th, 2012 08:38 PM
White Spyder
June 17th, 2012 01:53 PM
MDchanic
June 19th, 2011 08:48 PM
MDchanic
October 26th, 2010 01:26 PM
