Safety in Slow Idle Tuning
Old Apr 16, 2013 | 06:44 PM
pcard's Avatar
70 Cutlass SX
Tuning the carb idle with an auto transmission in Drive has always bothered me, even with the brake on and wheels blocked.
Could people share their favourite ways to do this?
Thanks, Peter
Old Apr 16, 2013 | 06:52 PM
1. Apply emergency brake.
2. Start engine.
3. Put in Drive.
4. Get out of car, stand in front, adjust idle.
5. Forget it's in Drive, blip throttle, get a quick eye-opener.
6. repeat.
Old Apr 16, 2013 | 07:13 PM
pcard's Avatar
70 Cutlass SX
Eric:
I like step 6 the best because it means you survived step 5
Peter
Old Apr 16, 2013 | 07:19 PM
coppercutlass's Avatar
Chevy budget Olds powered
I just leave it in park adjust go in put it in drive and back n forth.
Old Apr 16, 2013 | 07:47 PM
Lady72nRob71's Avatar
Just put bricks in front of all 4 wheels also for more comfort than just the parking brake.
Old Apr 16, 2013 | 07:48 PM
I do it with Eric's method but I lean over the drivers fender.
Old Apr 16, 2013 | 08:30 PM
pcard's Avatar
70 Cutlass SX
Leaning over the fender - where is the fun in that?
The place I keep the car has some wheel chocks and I definitely use those, even when I raise the front or rear to do some cleaning.
Old Apr 17, 2013 | 03:49 AM
Yeah, I actually, without exaggeration, don't think there's been a single time when I haven't done that at least once, and made the car (and me) jump.
Just make sure there's nothing within a few feet in front or back.
Old Apr 17, 2013 | 07:15 AM
2. Start engine.
3. Put in Drive.
I use this method, except I put the car in REVERSE. That way, when I'm standing in front of it, it doesn't come towards me. If you're really nervous about the holding ability of your e-brake, just have a helper sit in the car with foot on the brakes.
Old Apr 17, 2013 | 07:17 AM
rustyroger's Avatar
'87 Delta 88 Royale
If you have a rwd apply the parking brake and jack up the rear then put the axle on stands. You'll find out if the parking brake is in good shape as well.
Roger.
Old Apr 17, 2013 | 07:24 AM
brown7373's Avatar
It will be fine if the parking brake is working correctly and the wheels are blocked. Now if you forget and want to test the upper rpm limits, all bets are off. Still, a good idea to stand at the side or put in reverse. That said, the parking brake is much less effective in reverse. Also, the proper way to apply the parking brake is to step on the regular brake, hold it, then apply the parking brake. That sets it much more firmly.
Old Apr 17, 2013 | 08:04 AM
pcard's Avatar
70 Cutlass SX
Joe - now using Reverse is such a good idea I wonder why the CSM does not specify it.
B73 - I did not know that about parking brakes - is that something your Dad taught you?
Rusty - I would be worried about the vibration and stability, maybe it that would not be an issue.
Thanks everyone, Peter.
Old Apr 17, 2013 | 08:37 AM
brown7373's Avatar
I'm not sure when I learned that, but the regular foot brake applies the shoes firmly, and then the parking brake just hold the shoes in that position. Operating the parking brake by cable has a lot more resistance and doesn't apply them nearly as much.
Old Apr 18, 2013 | 07:41 AM
rustyroger's Avatar
'87 Delta 88 Royale
To pass the UK annual roadworthiness test the parking brake must give at least 25% efficiency without aid from the service brake.
If the brakes are properly set up that isn't a problem on any American car I've owned.
Putting the transmission in reverse is a good idea, as is having a helper with his foot ready to stamp on the brake.
But let's make the dangerous assumption the tuner knows what he (or she) is doing, in that case revving the engine enough to overpower the parking brake shouldn't occur. However this is the real world, so a back up safety measure is always a good idea, you can fix a damaged car for a lot less than a damaged Human.
Roger.
oldsfan_74
Apr 12, 2013 07:46 AM
ChefDeadpool
Sep 10, 2011 07:17 PM
al714
Nov 12, 2010 02:55 PM
wolfman98
Site Help
Nov 19, 2009 05:06 PM
Olds64
Aug 25, 2009 09:22 AM
