Rubber tip for blow gun.
Somehow the regulator on my blow gun got cranked up to max. The rubber tip blew off, I have searched all over the garage and can’t find it I figure the easiest way to find it to simply buy a replacement, then the missing tip with materialize out of thin air.
I have looked at all the hardware stores, I can find the type that screws onto a blow gun, mine slips on and snaps into place. I found the tip I need on the snap on truck today, they come in a variety pack. 2 of the 3 I will never use, and I have zero desire to send 60 bucks
The one I need is on the lower left. Anyone know where they can locate that particular tips?? Thanks.
Lot of the Carlisle swap meet tool vendors have those rubber tips. Last ones I bought were like 3 for 5 bucks.
I grinned like a mug when I found those things, because I had a few blowguns that had lost their tips over the years. Worked ok, just didn't concentrate the airstream and tended to blow stuff everywhere.
Normally I would agree. However, this particular style blow gun works perfectly for what I need. The tips on the Chinese blowgun are too wide to fit well in valve body/case passages to air test assembly’s after pump installation. The blow gun I have has has a long tip with a receiving groove, the rubber tip has a C-clip or something inside that kinda snaps into the groove.
Really? Is it the cooler flush stuff you get at Napa? If that’s the case, I’m going to try that. Thanks!!
