Rubber tip for blow gun.
Old May 31, 2022 | 03:40 PM
Somehow the regulator on my blow gun got cranked up to max. The rubber tip blew off, I have searched all over the garage and can’t find it I figure the easiest way to find it to simply buy a replacement, then the missing tip with materialize out of thin air.
I have looked at all the hardware stores, I can find the type that screws onto a blow gun, mine slips on and snaps into place. I found the tip I need on the snap on truck today, they come in a variety pack. 2 of the 3 I will never use, and I have zero desire to send 60 bucks
The one I need is on the lower left. Anyone know where they can locate that particular tips?? Thanks.
Old May 31, 2022 | 04:03 PM
Is this the one you need? Free shipping.
14mm VAC10-4011
And another...
Vacula VAC10-4011 Rubber Tip Nozzle Vacula VAC10-4011 Rubber Tip Nozzle
Old May 31, 2022 | 04:31 PM
Geeze, I don't think I've ever paid more than $5 for a complete blow gun WITH the rubber tip at a swap meet. This one is $7.99 on line. And yeah, this is one tool where Chinesium crap works just fine.
Old May 31, 2022 | 07:18 PM
rocketraider's Avatar
Oldsdruid
Lot of the Carlisle swap meet tool vendors have those rubber tips. Last ones I bought were like 3 for 5 bucks.
I grinned like a mug when I found those things, because I had a few blowguns that had lost their tips over the years. Worked ok, just didn't concentrate the airstream and tended to blow stuff everywhere.
Old Jun 1, 2022 | 02:47 AM
Normally I would agree. However, this particular style blow gun works perfectly for what I need. The tips on the Chinese blowgun are too wide to fit well in valve body/case passages to air test assembly’s after pump installation. The blow gun I have has has a long tip with a receiving groove, the rubber tip has a C-clip or something inside that kinda snaps into the groove.
Old Jun 1, 2022 | 06:30 AM
I actually have a tip from a spray can of trans cooler flush that uses a short length of hose that slips nicely over one of my blow guns for exactly this application.
Old Jun 1, 2022 | 11:28 PM
Really? Is it the cooler flush stuff you get at Napa? If that’s the case, I’m going to try that. Thanks!!
jensenracing77
Drivetrain/Differentials
Nov 18, 2019 10:26 AM
jwr7042
Jul 10, 2015 08:50 PM
kyootie
Apr 8, 2015 05:20 PM
Charly9g
Dec 1, 2013 05:55 PM
pigster
Mar 29, 2013 10:09 AM
