Roller rocker advice
Looking for some advice from the C.O. experts. I am considering running Harland Sharps roller rockers on my 455 build and was wondering if I needed to upgrade anything else like pushrods, valve covers, etc. Any other considerations?
Rockers
The HS is a great value rocker and fits under a stock cover with baffles but you'll need to double gasket. T&D machine IMO makes the best out there. They fit beneath my A/C baffled covers with ½" spacers. Personally I run oil restricted pushrods on all my RR engines...
HS shows the pedestal style rockers on their show, call them for fitment on the cast iron heads. If you’re planning on stock a/c you’ll want to remove the VC baffles, they won’t fit under the compressor bracket with double VC gaskets.
