Rochester 7041251 vrs 7041257
Old Nov 24, 2021 | 06:45 AM
OLDsBARRY's Avatar
So from what im picking up the only diff between the Rochester 7041251 vrs 7041257 is the jetting RIGHT ? Linkages r the same?
Looking for a 7041257. Found a 51 for a fair $$$$$ so thinking maybe it.
'71 442 Auto
Old Nov 24, 2021 | 07:44 AM
The only differences between the '1251 and '1257 carbs are the primary jets (0.070" in the '1251, smaller 0.069" in the '1257, primary metering rods are the same in both) and the secondary metering rods (AK rods in the '1251, AT rods in the '1257).
Old Nov 26, 2021 | 02:12 PM
shiftbyear's Avatar
Beware of anything that has signs of remanufacture. Tags, sand blasted castings ect. Also the fuel inlet threads need to be checked before buying, If they're stripped or damaged it could be an expensive fix. Also inspect the front top casting along the forward gasket area, some people really crank down on the mount bolts and warp the casting
Toms cutlass
Nov 11, 2021 03:55 PM
rr69ho
May 8, 2015 11:48 AM
Vader
Jul 13, 2014 07:28 PM
TexasGunner
Sep 12, 2013 07:23 PM
captn442
Apr 2, 2009 06:51 PM
