Right Turn Signal not working 70 Cutlass
Put LED bulbs in the rear, lights come on, beak lights work but the right turn signal does not come on. The turn signal light on the dash is dim and does not flash like the left side. Everything worked fine until I changed the bulbs to LED. Should I go back to standard bulbs or is it a switch issue. Any suggestions is appreciated. Thanks
You may need a turn signal flasher specifically for LED lamps.
It's a known issue with LED and some brands are worse than others. What is happening is the LED lamp's resistance is not high enough to trigger the flasher.
Otherwise known as no good deed goes unpunished.
