Rear floor brace the same from 69- 72?
Old Apr 24, 2021 | 12:19 PM
Al Curtis's Avatar
Help-
So I am starting replace the two rear floor sides in my 69 cutlass convertible. I also need to replace the rear brace as well. So frame off repair. After cutting out the old brace, i went about fitting in the new brace from Classic2 Current Fabrication, As I was clamping it in, it just seemed off- a little too high on the sides and two low under the existing drivetrain tunnel. So I laid my two new pans down and decided to see how the brace would fit on them. I could not see anyway that the brace would sit evenly on the pans - not even close. So I'm thinking wrong part- I check my receipt and the label on the part- they both say the brace is for 70-72 A bodies. I go to the website and they list the part I have as fitting 68-72 A bodies. So.... I thought before I speak with them I would get some knowledge from people who really know what is what. Thanks in advance
Old Apr 25, 2021 | 05:14 AM
Al Curtis's Avatar
Solved
I mistakenly ordered the front brace instead of the center brace (so the height issue makes sense)- too bad i already drilled holes in it for plug welding. Live and learn.
Al Curtis
Apr 18, 2021 08:14 PM
rpinnt
Body work
Mar 6, 2018 10:44 AM
Mike Sundy
Jul 6, 2015 07:10 PM
oldsmansugar
Body work
Dec 29, 2014 05:30 PM
Racer24ksi
Jul 20, 2014 02:56 PM
