Re: Fan shroud removal
Old Mar 6, 2014 | 07:24 AM
Bens71442's Avatar
Quick question on 1970 A body Olds. can fan shroud be removed, after top plate is removed, (without) removal of the engine fan?
ie. will the bottom section of the shroud clearance a installed fan? Or does the fan have to be removed at the same time the shroud is lifted out of place?
Old Mar 6, 2014 | 07:29 AM
oldsmobiledave's Avatar
interested
If there is a way to remove the fan shroud WITHOUT remove the fan belts & fan I would sure like to know about it. Subscribed.
Old Mar 6, 2014 | 07:30 AM
66400's Avatar
With a factory fan clutch you do have to remove the fan. All belts can stay in place.
That being said I do not know about a car with just a plain fan blade.
Henry
Old Mar 6, 2014 | 07:47 AM
If you can get the radiator out possibly.
Old Mar 6, 2014 | 09:48 AM
The short answer is no. The longer answer is also no.
Usually I unbolt the shroud (top and bottom) and push it back towards the motor. This makes it easy to remove the fan (and clutch if so equipped), at which point you can remove the shroud.
Old Mar 6, 2014 | 10:07 AM
Nop's Avatar
Nop
2-stroke 1-cylinder guy
Where did he write "without destroying it"?
Thanks for the question, need to replace my cracked one, was about to ask that, too.
Old Mar 6, 2014 | 05:00 PM
I had the same thought.
shamusj
Jan 13, 2015 05:44 AM
rmoths
Dec 21, 2013 11:03 AM
KZ442
Nov 9, 2010 05:01 AM
hammerit
Feb 24, 2007 08:06 AM
