Radiator overflow hose clamp - 68 442
Old Mar 31, 2023 | 09:29 AM
mclark68442's Avatar
Curious what style clamp was used for the coolant overflow hose where it attaches to the radiator fill neck on a 1968 442? Some type of spring clamp I would guess, and certainly not the hardware store worm clamp I have on there now.
Thanks.
Old Mar 31, 2023 | 09:51 AM
allyolds68's Avatar
It looks like nothing at the top and a clip near the bottom:
Old Mar 31, 2023 | 01:05 PM
^^^This. The hose was a friction fit on the nipple. There was no appreciable pressure in the hose since it vents to atmosphere when the cap overflows, so no need for a clamp. Probably saved half a cent per car.
Old Mar 31, 2023 | 02:46 PM
If you want, the smallest black zip tie would be a nice clip. Or, a spring clamp. Joe is right, though, you technically don't need a hose there, so it is not critical if it were to fall off, as it just makes a mess.
Doug Carner
Sep 2, 2020 08:29 AM
Fazer
Dec 15, 2019 08:01 PM
68442
Dec 22, 2016 11:49 AM
1979 hurst olds
Jun 17, 2013 03:50 PM
Dan Wirth
Oct 8, 2009 11:56 AM
