Quadrajet throttle shaft
Im rebuilding a carb from a 403. The primary and secondary throttle shafts are rusted. Could i just find a quadrajet from the junkyard with decent throttle shafts and clean them up and use those?
I would try and clean that base plate as an assembly. Soak in carb cleaner and try using a mild brush , think tooth brush not true grit steel bristles
I would guess some of that crud is carbon
If that does not work then maybe buy a different base or complete carb if you can.
All the best
70convert
Drivetrain/Differentials
March 7th, 2019 02:12 PM
sqeeek
March 14th, 2017 10:35 AM
64 CUTLASS KEN
November 22nd, 2010 05:17 PM
