Quadrajet throttle shaft
Old Aug 6, 2017 | 01:02 PM
Copper Nine Eight's Avatar
Im rebuilding a carb from a 403. The primary and secondary throttle shafts are rusted. Could i just find a quadrajet from the junkyard with decent throttle shafts and clean them up and use those?
Old Aug 17, 2017 | 08:16 AM
garage goat2's Avatar
Yes, as long as your throttle linkage hookup can be used.
Old Aug 17, 2017 | 03:25 PM
Qjet throttle shafts are NOT created equal. There are different throttle arms. There are different lengths. There are some secondary shafts with lockout linkage and some without.
Old Aug 18, 2017 | 03:14 AM
shiftbyear's Avatar
can you post a picture of the rusted shafts? were they moving freely or were the blades stuck in their bores also?
Old Aug 18, 2017 | 10:01 AM
Picture is all that great. They move freely. Just rusty
Old Aug 18, 2017 | 11:32 AM
11971four4two's Avatar
MOTORHEAD
I would try and clean that base plate as an assembly. Soak in carb cleaner and try using a mild brush , think tooth brush not true grit steel bristles
I would guess some of that crud is carbon
If that does not work then maybe buy a different base or complete carb if you can.
All the best
Old Aug 18, 2017 | 11:52 AM
TripDeuces's Avatar
Throw it in a blaster and it will clean right up. Soda blaster would work also but isn't real good with rust but it will polish up nice
Old Aug 21, 2017 | 04:57 AM
I stand corrected! Thanks Joe
70convert
Drivetrain/Differentials
Mar 7, 2019 02:12 PM
sqeeek
Mar 14, 2017 10:35 AM
Frogge467
Mar 24, 2012 11:09 PM
Gunfreak25
Mar 15, 2011 11:05 PM
64 CUTLASS KEN
Nov 22, 2010 05:17 PM
