What water pump pulley mat hes with kj crank pulley
Pulley gods
I've got a 7.25in 2in from front to surface 2 Grove waterpump pulley with s stamped on it. It lines up almost perfect but it kisses my crank pulley. What am I looking for? What pulley is the same just smaller
72 cutlass pulleys I believe I'm working with
what length water pump do you have? from timing cover to where pulley bolts?there are 3 sizes lower pulley dia? engine,hd cooling? pulleys have to match water pump length
lengths 5.1 5.6 6.0
lengths 5.1 5.6 6.0
WHAT WATER PUMP PULLEY MATCHES Kj CRANK PULLEY. 64 330 GOING INTO A 72 CUTLASS . Motor doesn't have a dampner it has the hub instead
Rob64cutlass
February 26th, 2022 07:17 PM
