What water pump pulley mat hes with kj crank pulley
Old Feb 28, 2022 | 04:39 PM
Ral's Avatar
Ral
Looking for a smaller water pump pulley that the S 1972
Have a 72 water pump pulley that kisses the crank pulley. No ac 2 Grove
Old Feb 28, 2022 | 05:25 PM
Ral's Avatar
Ral
Pulley gods
I've got a 7.25in 2in from front to surface 2 Grove waterpump pulley with s stamped on it. It lines up almost perfect but it kisses my crank pulley. What am I looking for? What pulley is the same just smaller
72 cutlass pulleys I believe I'm working with
Old Feb 28, 2022 | 06:46 PM
Gerald Nickels's Avatar
I have some pulleys so what size do you have OD or size?
Gerald
Old Mar 1, 2022 | 08:32 AM
oldolds88's Avatar
what length water pump do you have? from timing cover to where pulley bolts?there are 3 sizes lower pulley dia? engine,hd cooling? pulleys have to match water pump length
lengths 5.1 5.6 6.0
Old Mar 1, 2022 | 09:15 AM
nicks1966's Avatar
Here is the chart for 72 350 pulleys, as stated above this is only correct if you have the 72 pump length.
Old Mar 1, 2022 | 11:27 AM
Ral's Avatar
Ral
WHAT WATER PUMP PULLEY MATCHES Kj CRANK PULLEY. 64 330 GOING INTO A 72 CUTLASS . Motor doesn't have a dampner it has the hub instead
Old Mar 1, 2022 | 11:45 AM
nicks1966's Avatar
Go look at the picture I put on you other post, it has the part number and the letter code.
Old Mar 1, 2022 | 12:19 PM
Ral's Avatar
Ral
hey thank you I didn't see that pic.
Old Mar 1, 2022 | 01:34 PM
11971four4two's Avatar
MOTORHEAD
The aftermarket pulleys are too big
The water pump and crankshaft pulleys will contact each other
I have some 2 groove factory pulleys KN water pump and KJ crankshaft non A/C factory pieces
Old Mar 1, 2022 | 07:17 PM
It's really not in your best interest to span the forum with multiple threads on the same topic.
Old Mar 2, 2022 | 09:42 AM
oldolds88's Avatar
you have a pm
Dave Siltman
Oct 15, 2025 06:36 AM
Ral
Mar 1, 2022 09:15 AM
Rob64cutlass
Feb 26, 2022 07:17 PM
ctosiflying
Mar 22, 2016 03:20 PM
jwr7042
Oct 22, 2014 06:23 PM
