Power steering pump
Power steering pump
Not sure if it has been talked about but I purchased a 67 cutlass supreme the previous owner put a 455 in it and just slapped power steering pump in any holes I don’t think it’s in the right spot since the pulley does not line up with any pulley does anyone know the placement on a 455 I think the brackets wrong since everywhere I look I’m told it’s a three piece bracket and I only have one any info would be helpful thanks
the 67 power steering has a two piece setup, the bracket bolts to the driver side cylinder head and the brace goes over the valve cover, the 68 and up has a three piece setup but will not fit unless you modify the lower mount. the 67 frames are one inch narrower the the 68 and up , this causes the bracket to hit the steering box and can't be bolted in.
post some pictures of what you have.
