Passenger door won't open from outside
Old May 11, 2015 | 08:12 AM
mauls's Avatar
Green Horn
I'm not sure what's going on here, but my exterior passenger door handle will not open the door. It's the standard push button door handle.
I took off the door panel, and noticed that the push rod on the push button is sliding between latch, and a hinge or something.
Obviously something is not lined up but I can't seem to move anything on the interior latch to get it to line up.
Any idea's? I guess I could try replacing the exterior handle, but I don't think that's the issue.
Old May 11, 2015 | 08:21 AM
The short rod on the back of the pushbutton may be bent.
Take the handle off the door and look at it, then look in the hole and see where it's supposed to go, and see if you need to bend it slightly to hit its target.
Old May 11, 2015 | 05:46 PM
mauls's Avatar
Green Horn
I took the door handle off and bent the push rod so that it makes contact. The problem is that the push rod rotates in the handle so after a few opens it falls back to where it misses.
I'll keep investigating it but may try with a new door handle.
Old May 11, 2015 | 06:53 PM
I know that the door handles of the different years and models all look the same, but that some are actually very different - I've only seen buttons where the pushrod was stationary and couldn't rotate.
It is possible that the rotation is the problem.
67townsedan
Jan 5, 2015 07:05 AM
yankees
Dec 21, 2012 12:41 PM
silverriff
Body work
Jul 23, 2010 01:01 PM
Tangovino
Feb 11, 2010 02:58 PM
poppy
Jun 18, 2006 11:19 AM
