Paint removal from plastic
What is the best way from your experiences, to remove paint from plastic pcs like grills or interior pcs? An example would be a set of 70-72 grills painted black. I know of a lot of chemicals and strippers but dont want to melt the plastic or use a chemical that may be too harsh. Baking soda blast may be an option also? Sanding can't get in all the nooks and crannies.
Depends a lot on if the black grill was painted with a paint with a hardener in it to began with. Test a small area that doesn't show with lacquer thinner. If it dissolves the black and doesn't make the base plastic soft or sticky it should work. Graffiti remover is usually a safe option also....Tedd
